Plot the full body when a symmetry region is defined
    • pgl
      How to plot the full body when a symmetry region is defined?
    • Arun Kumar
      if a symmetry is defined with Zaxis as normal, you can activate Graphical expansion (Beta) into the symmetry folder (not the symmetry region) and request a Cartesian, Half expansion with a tiny negative Delta Z. That will not work with Delta Z = 0
  • The topic ‘Plot the full body when a symmetry region is defined’ is closed to new replies.
