Refine only coarse cells
    • admin
      1. Open Adapt->Iso Values (If you cannot open Initialize) 2. Options and Inside, and the Iso-values of the "Adaption ..., Cell Refine Level" 3. Press Compute and check the Max value 4. Enter the value of the Max directly into Iso-Min and Iso-Max and press Mark. If you cannot Mark, it may have reached the maximum resolution level. If that is the case, increase the Max Level of Refine by one in Controls. 5. Press Manage 6. Press Exchange, then Adapt
    • admin
      How do I refine only coarse cells?
  • The topic ‘Refine only coarse cells’ is closed to new replies.
