September 27, 2017 at 11:19 am
nselvara
Ansys EmployeeCan I use STL files to create solid geometry in SpaceClaim Engineer?
October 17, 2017 at 7:33 am
Arun Kumar
Ansys EmployeeYes, there is a check box in the Options menu under the File options section for STL files: Import as body. Check this option on to import STL files as solids. This imports a solid with the same faces as the STL mesh and you can modify the geometry the same way you would edit solids created in SpaceClaim. Check ON the Merge Faces option to merge the mesh faces during import
September 10, 2020 at 4:05 pm
Ojas_Babannavar
SubscriberWhen I do this, a lot of facets are being created in the solid body. How to get a complete solid body with just the original number of facets?. -
September 10, 2020 at 7:07 pm
peteroznewman
Subscriberwhen you import an STL file, you get exactly the original facets that are in the STL file.nDo you mean that if you have a smooth solid body, put a mesh on it, deform it in Static Structural then export the deformed shape, you get an STL file with a lot of facets?n -
January 18, 2023 at 8:04 pm
Sneh Patel
SubscriberHi Peteroznewman,
I have the same issue. I got a deformed geometry from static structural then exported that deformed shape as STL file. When I open it in HFSS, it becomes distorted. So I tried converting STL file to solid body in Spaceclaim, but I am stuck.
Ultimately, I was to perform EM analysis on deformed shape in HFSS.
Thanks,
- The topic ‘Using STL files to create solid geometry in SpaceClaim Engineer’ is closed to new replies.
- Add-in Error Excel
- Spaceclaim problem
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- New Computer
- Inconsistent Script
- MISSING SIMULATION SECTION/RIBBONTAP
- Unable to attach to geometry file 2025R2
- How would I select specific components and all bodies under it?
4623
1535
1386
1215
