October 4, 2017 at 12:20 pm
Vishal Ganore
Ansys EmployeeYes. First create a name selection that contains the body for which you want to specify a different initial temperature (e.g., create a name selection called Selection1). Then insert a Command Object in the Analysis Branch that issues the IC command. IC,Selection1,Temp,113 ! for an initial temperature of 113 degrees.
October 4, 2017 at 2:39 pm
pgl
Ansys EmployeeHow can I define a different initial temperature for a specific body in my thermal analysis in Mechanical
April 15, 2019 at 9:15 pm
Sanjoy
SubscriberI have a multilayer body(basically multiple bodies forming one part). So how do i define a single temparature for the object?
April 16, 2019 at 1:53 am
Sandeep Medikonda
Ansys EmployeeStart a new discussion and post some pictures to explain your problem. Take a moment to refer to the Guidelines on the Student Community.Â
This discussion will be marked to be closed.
- The topic ‘Define a different initial temperature for a specific body in my thermal analysis in Mechanical’ is closed to new replies.
6435
