September 27, 2017 at 11:19 am
admin
Ansys EmployeeIs it possible to read CFX files in FLUENT?
October 17, 2017 at 5:19 am
admin
Ansys EmployeeCFX's * .def file or * .res file can be loaded as a mesh in Fluent through File ->Import->CFX. Select Definition File ... for * .def file or Result File ... for * .res file. After the mesh is read, do Grid->check. Analysis results of CFX are in the CGNS format. In CFX, Solver of Tools->Export Result can export in CGNS format. In Fluent, File->Import->CGNS->Data will allow the data to be read. However, data of multiphase flow is incompatible) Note: There is no Import function for the settings and parameters of the boundary conditions. These will have to be set manually.
March 28, 2019 at 7:13 am
Christine19KIT
SubscriberHi!
If I import the data like this in Fluent, I only have data for x-,y-,z-velocity, temperature and pressure. Is it possible to import data for turbulence as well?
Thanks!
- The topic ‘Read CFX files in FLUENT?’ is closed to new replies.
4597
1505
1386
1209
