TAGGED: acoustics, acousticwaves, ffowcs-william-hawkings
April 11, 2023 at 1:17 am
YH
SubscriberHelloÂ
I'm calculating sound generated by water flow in pipe by using LES and Ffowks Williams Hawkings model (FW-H model).
My question is what boundary condition does FW-H model use?
The theory guide mentions that the model is applicable to the far-field acoustic wave and acoustic propagation toward free space. Does it means each source grid is a point source? The pipe wall isn't the boudary condition such as reflection?
Also I'm a little bit confusing. Can we change the boundary condition of FH-W model by using the Boudnary Acoustic Wave Models? https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v212/en/flu_ug/flu_ug_sec_nrbc.html
Thank you.
April 12, 2023 at 3:43 pm
Federico
Ansys EmployeeIn general, the FW-H model is not applicable to internal flow acoustics such as noise propagation in ducts, but you could have a case where the internal flow is your source and you will be using FW-H to model sound propagation downstream in an external domain.
FW-H solution assumes that the source region radiates sound through a free field environment with no obstacles between the source and receivers. Hence, FW-H will be less sensitive to BCs outside of your source region. -
April 12, 2023 at 4:44 pm
YH
SubscriberThank you so much for your responce. I still cannot get completely. Even it calculates acoustically far-field, doesn't it need boundary condition? Does free field become the boudary condition?
FH-W model assumes free field, does it mean the wave is radiated uniformly to all the direction like point source?
Thanks!
April 12, 2023 at 5:18 pm
Federico
Ansys EmployeeThe boundary conditions will depend on the model and application that you are solving for. The FW-H model solution is developed as integral terms of the acoustic pressure from the integration surfaces surrounding the source region. Outside of this source region, yes the sound is radiated through a uniform medium. Because of this, you can even set up receiver outside of your simulation domain.Â
April 12, 2023 at 9:33 pm
YH
SubscriberÂ
I see… There’re something that I still don’t understand. In case, what does decide the wave number? It means if you place the several receivers in same r with different direcections in the figure, they show same wave?
- The topic ‘Boundary Condition of Ffowcs Williams Hawkings model’ is closed to new replies.
5874
1306
