An error occurred inside the POST PROCESSING module
    • Abdualraouf
      I am getting this error while i am checking the gab for the contacts, and some contact appear as inactive i don't understand where is the problem is , and the model fail to converge with many warnings.
      any help will be very appretiated.
       *** WARNING ***                         CP =      43.594   TIME= 22:45:48
       There are no selected nodes.
        Parameter _MINX will be set to 1.2676506E+30.
        Parameter _MINY will be set to 1.2676506E+30.
        Parameter _MINZ will be set to 1.2676506E+30.
        Parameter _MAXX will be set to -1.2676506E+30.
        Parameter _MAXY will be set to -1.2676506E+30.
        Parameter _MAXZ will be set to -1.2676506E+30.
       *** ERROR ***                           CP =      43.672   TIME= 22:45:48
       Node 0 is not defined.
       ***** WARNING  *****
       Undefined parameter used in field  3 (NX(_NTETS(_I))+_DELTA)
       Line=n,_nspr,nx(_ntets(_i))+_delta,ny(_ntets(_i)),nz(_ntets(_i))
       ***** WARNING  *****
       Undefined parameter used in field  4 (NY(_NTETS(_I)))
       ***** WARNING  *****
       Undefined parameter used in field  5 (NZ(_NTETS(_I)))
       *** WARNING ***                         CP =      43.672   TIME= 22:45:48
       Undefined parameter used for coordinate 1.
        A value of 0.0 will be used.
       Undefined parameter used for coordinate 2.
       Undefined parameter used for coordinate 3.
    • Ashish Khemka
      The message 'There are no selected nodes' indicates that there are no nodes selected. Are you using a command object? If yes, then can you please ensure that the nodes are selected?
      Ashish Khemka
    • Abdualraouf
      THANK YOU ASHISH, I AM NOT USING COMMAND OBJECT.
      when i am trying to evaluate contact tool i am facing troubles with it ''an error occurred inside the POST PROCESSING module'' , after i chaneged the reinforcemnt bar model type from ''reinforcement '' to ''beam'', i got results with contact tool.
      its quite complex model though i am searching for a linear results.
  • The topic ‘An error occurred inside the POST PROCESSING module’ is closed to new replies.
