Dimension my model in in SpaceClaim Engineer?
    • nselvara
      To create dimensions for annotating a part, use the Dimension tool in the Annotation group on the Detailing tab. §All dimensions are placed on an annotation plane in design mode, which you can toggle on or off for display purposes. §Dimensions display on the drawing sheet (if you are dimensioning a model in a drawing sheet). §You can use the Ruler option in the Pull or Move tool to create temporary dimensions while editing a part. You can save these dimensions by creating a group in the Groups panel. These dimensions can then be used to drive changes with the Pull or Move tool
    • nselvara
      How do I dimension my model in in SpaceClaim Engineer
  • The topic ‘Dimension my model in in SpaceClaim Engineer?’ is closed to new replies.
