Change the time step size using TUI commands and journal files
    • admin
      To change the Time Step Size using the TUI command (for example, to 1), enter the following: /solve/set/time-step 1.0 When you use the following journal file, the Time Step Size is 0.2 for 10 Time Steps then 0.5 for another 10 Time steps. /solve/set/time-step 0.2 /solve/dual-time-iterate 10 30 /solve/set/time-step 0.5 /solve/dual-time-iterate 10 30
    • admin
      How can I change the time step size using TUI commands and journal files?
  • The topic ‘Change the time step size using TUI commands and journal files’ is closed to new replies.
