Photonics
Photonics
Neff Vs voltage for LiNbO3
    • Pratishtha Agnihotri
      How can I see a change in the effective index vs voltage in CHARGE for LiNbO3? I browsed through the ferroelectric modulator example provided in Lumerical, it is for BiTiO3. I need to add all electrical and optical properties of LiNbO3 which I can't find on the internet. How should I proceed further?
    • Amrita Pati
      Hi Pratishtha,
      Unfortuanely, you would need those electrical and optical properties to be able to simulate the index vs. bias behavior of LiNbO3 in CHARGE. I would suggest you to look at some existing papers to see if you can get the values. I don't believe there is an alternative approach if we don't have those values.
      Amrita
    • Amrita Pati
      Hi Pratishtha,
      Lithium Niobate has been added to the material database in CHARGE in the newest release (2023 R1.2).
      I would suggest you to install this release and take a look. Thank you!
      Amrita
  • The topic ‘Neff Vs voltage for LiNbO3’ is closed to new replies.
