How to export a mesh from Fluent to CFX and import it back again to Fluent
    • mkhademi
      Hi everyone,
      I have a 2D mesh created by ICEMCFD. I would like to add one layer in transverse to make it 3D. I read that one way is to import Fluent mesh to CFX. I did it and it added one layer. Now, I don't know how to save the resultant 3D mesh in CFX and export it back to Fluent. I appreciate any suggestions.
      Thank you!
    • Keyur Kanade
      You can use extrude mesh in ICEMCFD to make it 3D and then export it Fluent from ICEMCFD. From CFX, try CGNS export if available.
      Please go through help manual for more details
      Keyur
      Fluids Engineering Courses | Ansys Innovation Courses
    • mkhademi
      Thank you Keyur. I will try ICEMCFD too.
    • DrAmine
      Read in CFX the Fluent Case / Mesh File write a definition file and import that in Ansys Fluent if you do not want to go via ICEM CFD or other tools. In Ansys CFX you can then tell how to intepret the 2D mesh.
    • mkhademi
      Hi DrAmine,
      Thank you, ICEM can be problematic for complex geometries. I tried yesterday, it extrudes the mesh, but not the blocks.
      I only need one layer in the width, and if I can handle it through CFX, it will be great. Should I write the definition file in CFX-pre? Thanks.
    • mkhademi
      Thank you DAmine. It worked with the definition file of CFX.
    • DrAmine
      Welcome!
Viewing 6 reply threads
  • The topic ‘How to export a mesh from Fluent to CFX and import it back again to Fluent’ is closed to new replies.
