Ansys Learning Forum Forums Discuss Simulation Electronics HFSS NFC ANTENNA SIMULATION Reply To: HFSS NFC ANTENNA SIMULATION
Praneeth
Hi Simay,
Thank you for reaching out and your patience is much appreciated.
It looks like your setup is not correctly set for the antenna simulation. As you are a new user, it is suggested to go through the getting started guides (GSG) which can help you with a correct simulation setup. Go through - probe fed patch antenna GSG to learn the detailed steps available in the Help menu. Alternatively, you can access the online version of this GSG here - Ansys Electronics 2023 R1 - Set Up the Project.
Additionally, you can also go through antenna examples to get hands-on experience with antenna simulation in Ansys HFSS.
Best regards,
Praneeth.
