Eigenvalue buckling analysis with cracks
    • Divya Giri
      Hello Everyone,
      I need to analyze the influence of cracks on the buckling behavior of the bamboo model. For that, I generated a Semi-elliptical crack and simulated total deformation in the presence of that crack. But as I tried to solve the model on Eigenvalue buckling,  an error occurred that stated it was not possible to do the analysis with the fracture folder. Could anyone please help me through this?
      Best Regards,
      Divya Giri
    • ErKo
      Hi
      Think the message is very clear.
      Workaround. Instead of modelling a crack as you did, just try to make it as a slot (removing material in the cad as shown below), and that will be ok for dynamic eigenvalue or harmonic analysis.
      All the best
      Erik
    • Divya Giri
      Thank you for suggesting it. Is it possible to create a slot through Space claim?
      Divya
    • ErKo
      Hi
      yes. I mean “slot” is just a void/cut in the gemoetry like, so you can just skecth that rectangular cut/slot and use the Pull tool, to “pull” it into the part but using the Cut option in order to take away the material and so to generate a void/slot. See the help manual and perhaps the internet (see a link below for a tutorial) for more info on the Pull tool in SpaceClaim.
      https://www.youtube.com/watch?v=pUAODCkzK8U
      Hope this is clear
      Erik
    • Divya Giri
      It's clear. Thank you :)
      Divya
    • ErKo
      That is great - I have also added a tutorial. Hope it helps. Erik
    • Divya Giri
      Perfect!!
      Thank you so much!
      Divya
Viewing 6 reply threads
  • The topic ‘Eigenvalue buckling analysis with cracks’ is closed to new replies.
