Ansys Learning Forum Forums Discuss Simulation 3D Design Convergence criteria is not met while running CHT analysis in Refine mode of ANSYS Discovery 2021 R1. Re: Convergence criteria is not met while running CHT analysis in Refine mode of ANSYS Discovery 2021 R1.
prathap
Hello Subashni
I hope the problem setup was good to solve. An error free solution from your end will help to solve problems with similar setup.
