Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › The difference between Mechanical and Disco mode analysis results. › Re: The difference between Mechanical and Disco mode analysis results.
November 29, 2021 at 4:26 am
Subashni Ravichandran
Hello Jang
Can you please specify if you are using the Explore mode or Refine mode in Discovery?
You can share the files at ansys-discovery-support@ansys.com
