Ansys Learning Forum Forums Discuss Simulation 3D Design Flow around Rotating walls Re: Flow around Rotating walls
Charudatta Bandgar
Dinakara It will be difficult to understand otherwise. If you want I can share the secure transfer link. Or you can share the screenshot to me through mail. I think what is happening here from the error message is that two different boundary conditions are either applied on the same face, which is creating the conflict. I would suggest you check the boundary conditions once, and see if that is the case.
Regards.
