3D Design
3D Design
Unable to import geometry file in Discovery Aim for FSI simulation.
    • ajay.rb
      Importing of the file is showing the error "Update failed for the data import component in the study". I have attached the screenshot. I tried to import the geometry through spaceclaim then also it is throwing an error. Please help. Thanks.
    • Naresh Patre
      Hello Ajay
      Which file format are you trying to import? Can you check if you are encountering the same issue for other file formats like step, parasolid, etc.?
      Did you install CAD translators for the Discovery Ultimate Geometry Interface Bundle? If not, can you install it and try importing the model again?
  • The topic ‘Unable to import geometry file in Discovery Aim for FSI simulation.’ is closed to new replies.
