3D Design
3D Design
how can i input a time variable input condition
    • alain.benchissou
      Hi
      I know it is possible but am new with DIscovery Ultimate
      for a fluid transient analysis,
      i would like to be able to input a pressure on which the magnitude would be a function of time (for example at the beginning the pressure is maximum, at the end of the end time of analyse, the value goes down to Oà.
      thanks for your help
    • Gaurav Sharma
      Hi benalain
      It is possible to write pressure as an expression of time in Discovery AIM but this is not possible with Discovery Live. I believe your problem is concerned with AIM.
      You just have to start writing an expression under the pressure tab and as you write “Time”, program recognizes this as standard analysis time:
      In the example below, I have written an expression such that pressure drops down to 0MPa at T = 100 seconds and stays at zero even if the analysis proceeds further. Please note the use of conditional statement and rectangular brackets are used to specify units in order to ensure dimensional accuracy.
      I hope this helps.
      Thanks & Regards,
      Gaurav
    • alain.benchissou
      You are right, it is for AIM
      thanks, i will test this
      is it possible to multiply the pressure by a function i would describe later? (we use to do this traditionnaly in FEA codes)...
      • Gaurav Sharma
        benalain
        I guess any function of time should not be a problem. I may provide more precise information if you can please elaborate on what kind of a function you are trying to have.
    • alain.benchissou
      any function for example a linear one with an expression like : 100 x TIme + 50 ..
    • alain.benchissou
      i wrote as you suggested ; it seems to be OK ; indeed there is a value disaplyed corresponding at the initial time.
      Is there any way to plot the function i defined?
      • Gaurav Sharma
        benalain
        Yes there is. You can see a small arrow right next to the function defined. Click on it and it will popup chart option for you as shown below:
        Gaurav
      • alain.benchissou
        Gaurav_ANSYS
        Thansks for that
        hi, are using version 19.1 or 19.2?
    • Gaurav Sharma
      The snapshots I shared with you are from 19.1.
      Gaurav
Viewing 5 reply threads
  • The topic ‘how can i input a time variable input condition’ is closed to new replies.
