October 28, 2020 at 2:20 pm
Charlie
SubscriberÂ
Since 1 week (and the update of windows), several of our customers have lost the possibility of "double click" on .scdoc or .stp in SpaceClaim
After having tried the modifications in the windows registry by adding  USERUNNINGSPACECLAIM = true" / UseLicenseMode = true
in HKEY_CLASSES_ROOT SpaceClaim.Document Shell Open command
HKEY_USERS Software Classes Applications SpaceClaim.exe shell open command it still doesn't work, do you have an idea? -->Error message: "No valid license file was found. How do you want to proceed?" -
October 29, 2020 at 4:07 am
Charudatta Bandgar
SubscriberHello charlie ,
I am looking into this issue, I will get back to you as soon as possible.
Regards.
November 13, 2020 at 10:02 am
Charlie
SubscriberHello,
Do you have any news about this problem?Regards
November 17, 2020 at 5:44 am
Charudatta Bandgar
Does double click work if SpaceClaim is already open? Please go through this post, and see if it solves the issue.
I have filed a bug (BUG ID:Â 367451), I have not heard back from the developers yet, I will let you know as soon as possible.
Regards.
January 11, 2021 at 4:15 pm
Roberto Granito
SubscriberHello Charudatta Bandgar
I had the same problem today, no way to fix? I have already changed log files and scdoc files do not open with double click.
Why does this happen to some users? on some versions of windows 10
Best Regards
January 11, 2021 at 4:31 pm
Roberto Granito
SubscriberI have already changed windows registry and scdoc files do not open with double click.
January 19, 2021 at 8:02 am
Roberto Granito
SubscriberCharudatta Bandgar Hello
The customer is asking me for an answer
best regards
January 19, 2021 at 8:09 am
Charudatta Bandgar
SubscriberI have asked the developers, Roberto . I will let you know when I will know more.
Regards.
January 25, 2021 at 2:13 pm
Roberto Granito
I am attaching the error it releases in the 2021 version if you need it
Best Regards
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions-
March 24, 2021 at 8:43 am
Roberto Granito
SubscriberCharudatta Bandgar  HelloÂ
do you have any news to solve this problem? did you understand the cause?
Best Regards
April 19, 2021 at 11:42 am
Roberto Granito
More than a month has passed, the customer would like an answer
Best Regards
April 20, 2021 at 10:57 am
Roberto Granito
SubscriberNaresh Patre
April 21, 2021 at 12:19 pm
Roberto Granito
Subscribercharlie Hello
were you able to solve the problem?
Best Regards
April 21, 2021 at 12:36 pm
Charlie
SubscriberRoberto Hello ROBERTO,
No sorry.... I got used to the idea and I gave up. I use drag and drop and I'm waiting for the next version (2021R2 hoping to have a good surprise)
April 21, 2021 at 12:35 pm
Naresh Patre
Ansys EmployeeHello Roberto
Let me go through this discussion and get back to you.
April 23, 2021 at 8:13 am
Roberto Granito
I solved the problem by creating a new user with administrator rights and installing spacecliam inside C: ProgramData.
Installing it in the default location was still giving me problems.
The program data folder is shareable for all users it might be better to install it here.
Before installing it I uninstalled spaceclaim and deleted all hidden foldersBest Regards
- The topic ‘double click on .scdoc 2020R2’ is closed to new replies.
4728
1565
1386
1242
