3D Design
3D Design
AIM: how to get the pressure drop of the pipe section in flow analysis
    • sjyu
      I want to get the specific section pressure of the pipe after the flow analysis is finished. But there is no geometry face for selection.
      how to get the pressure drop between 2 section where is no face for selection?
      thanks!
    • sjyu
      I create the plane, but I can not use this plane for calculated value. how to get the average value of the specific section?
    • Naresh Patre
      Hello Frank
      Under Results, if you add "Pressure Drop" result, you have the option to create/add a plane for measuring the pressure drop. See attached snapshot.
      Alternatively, you can add a "Calculated Value" result and calculate average pressure on a plane. See attached snapshot.
      If you are still facing issues, please share some snapshots to better understand the problem.
  • The topic ‘AIM: how to get the pressure drop of the pipe section in flow analysis’ is closed to new replies.
