3D Design
3D Design
Discovery AIM 2019 R1 failed with CLR20r3 error message.
    • kin
      In the beginning, AIM could start successfully and I got into the Structure template but it failed when importing geometry in it.
      The error message you can see as shown in picture 1 and picture 2.
      I've reinstalled it but it didn't work.
      How to fix this problem?
      Thanks & Regards.
    • Naresh Patre
      Hello Kin
      One user faced a similar error with SpaceClaim and reconfiguring Firewall helped to overcome the issue. Please check out below discussion thread. Can you try it out and let me know if it doesn't help? You may have to take help from your IT team in this case.
      /forum/forums/topic/spaceclaim-has-stopped-working-3/
      • kin
        Hi Naresh Patre ,
        We've reconfigured the firewall and antivirus software as shown in the attachment picture 3 but it still doesn't work.
        The problem is in the same condition as described above.
        We're looking forward to having a solution to this problem.
        Thanks & Regards.
    • Naresh Patre
      Kin
      Thanks for your reply. I will check with the installation team and let you know. Meanwhile, can you check if the user has admin rights?
      • kin
        Hi Naresh Patre ,
        It's certainly sure that the user reconfigured the firewall and antivirus with administration right.
        Thanks for your assistance.
        Thanks & Regards.
    • Naresh Patre
      Hello Kin
      Can you go to C:UsersAppDataLocal and rename following folders:
      1. rename folder named "SpaceClaim" to "SpaceClaim_old"
      2. Go Ansys folder and rename folder "v193" to "v193_old".
      Now, restart AIM and check if you are still encountering the same issue.
      • kin
        Hi Naresh Patre ,
        We renamed the two folders but it still doesn't work.
        Thank & Regards.
    • Naresh Patre
      Hello Kin
      Can you check following points:
      1. The OS is supported by the ANSYS version used by the customer
      2. The user would be running Discovery Aim on Remote Desktop.
      3. The Graphics driver would be old.
      • kin
        Hi Naresh Patre
        The OS is Windows7 and the version of AIM is 2019 R1 which is compatible with Windows7.
        We updated the driver but it still didn't work.
        Thanks & Regards.
    • Naresh Patre
      Hello Kin
      Can you check if Discovery AIm is running on Remote Desktop?
      • kin
        Hi Naresh Patre
        No, it didn't run on Remote Desktop.
        Thanks & Regards.
    • Naresh Patre
      Hello Kin
      Renaming the folders mentioned earlier has helped to overcome this issue. I am not sure why it is not helping in this case. What version of .NET Framework is installed?
      • kin
        Hi Naresh Patre
        The version of NET Framework is 3.5 .
        Thanks & Regards.
    • Naresh Patre
      Hi Kin
      I have contacted you separately through email seeking additional details.
      • kin
        Hi Naresh Patre
        I've replied to you with some information.
        Thanks & Regards.
    • Naresh Patre
      Deactivating detect contact automatically option helped to overcome this issue.
Viewing 8 reply threads
  • The topic ‘Discovery AIM 2019 R1 failed with CLR20r3 error message.’ is closed to new replies.
