3D Design
3D Design
Can’t start Discovery Standard installation
    • papp
      I'm not able to install the Discovery Standard 2019R3 package on my computer, as the "Install ANSYS Products" text is not clickable in the Installation Launcher.
      Please advise a solution to this issue.
      FYI: The problem is present before and after a Win10 (Education) re-install and using the Ultimate package as well. 2019R2 was working fine previously.
      FYI2: My GPU VRAM is only 2 GB, but it shouldn't be a problem, if I'm correct.
      Thanks,
      Bálint
    • Brian Bueno
      Bálint Papp
      This does not look like the usual installer. Make sure you've downloaded the file from the forum download page: Discovery Downloads
      The installer on the ANSYS Customer Portal is configured for a floating license by default.
    • ANSYS_MMadore
      Bálint Papp
      Please also ensure you have extracted the download prior to trying to install. Failure to run the setup from the extracted files can result in similar behavior.
    • papp
      Brian Bueno Matt Madore
      Thanks for your replies. I downloaded the installer package from the official page, and unzipped it before running setup.exe.
      I'm going to check the licensing with my colleagues and get back to you with updates.
    • papp
      I moved the whole installer folder to C: (the drive where Windows is installed), and ran as Administrator. This way the familiar installer window popped up and worked just fine.
Viewing 4 reply threads
  • The topic ‘Can’t start Discovery Standard installation’ is closed to new replies.
