February 9, 2021 at 7:34 am
Roberto
SubscriberHello many customers are calling me saying that spaceclaim does not take licenses nor log in nor with the command prompt.
I hope this problem will be resolved soon
Best Regards
February 9, 2021 at 7:56 am
Subashni Ravichandran
Forum ModeratorHello Roberto We have received similar complaints from other users as well. I have escalated this issue with my team to check for issues at our end. Have you tried refreshing your licenses using the command prompt options? -
February 9, 2021 at 8:01 am
Roberto
SubscriberCiao Subashni
I tried to activate the license with the command prompt and it doesn't activate.
It is not possible all the time to have these licensing issues, you should have an alternative plan when this issue occurs as another support server.
In this way economic damage is caused to companies and the entire technical offices remain stationary and do not produceBest Regards
February 9, 2021 at 9:57 am
I understand the inconvenience caused. Let me check back with my team to see if there is any alternative.
February 9, 2021 at 2:24 pm
Roberto
SubscriberSubashni Now it is possible to solveÂ
- Open Command prompt in admin mode
- In the command prompt, type in:
cd C:Program FilesANSYS Incv211licensingclientwinx64 - Once in that directory, run the following command:
ansysls_client.exe -RefreshLicenseEntitlements
February 10, 2021 at 8:04 am
Roberto
SubscriberHello Subashni Naresh PatreCharudatta Bandgar
I hope that yesterday's problems won't happen again as they have caused us many problems.
It is not possible that the licenses do not have a support server in case of problems.
If the licenses connect to the internet once a month to check the license why if the server does not work, the license does not work? Does it mean that every day the license requires an internet connection with the exchange of information on the server?Best Regards
February 10, 2021 at 8:33 am
Naresh Patre
Ansys EmployeeHello Roberto
Yesterday's issue was a very rare incident which affected many SpaceClaim users having Named User (subscription) license. To give you some more information about this issue, earlier there was an issue with the SpaceClaim floating license that it would have enabled 2 simultaneous sessions. So a correction was made to fix it, but it resulted in an additional error in the subscription license which resulted in unavailability of SpaceClaim license. We again apologize for the inconvenience caused and we'll work on to avoid repeating such situations in future.
I think this issue could have affected only those users who were connected to internet. The subscription license can remain activated for a period of 30 days without internet connection. So for offline customers, I don't think they should have encountered this problem. Did you see any users who were not connected to internet but still encountered the issue?
If any of the customers are still facing the issue, please share the email address of the customer and the .ansys folder (zip it) from %temp% location.
Our sincere apologies once again!
February 10, 2021 at 8:53 am
Roberto
SubscriberHello Naresh Patre
Ok all clear, the problem only occurred in users connected to the internet
Best REgards
- The topic ‘URGENT server license is not working’ is closed to new replies.
5014
1682
1387
1248
