March 23, 2021 at 12:01 pm
ventura
SubscriberHi, Recently SpaceClaim starts to export DXF/DWG in different way than before. Circles (holes) in DXF have a parameter called "Z Normal", it can be 1 or -1 (in our cases). Before latest version in the same exportation the Z Normal was 1 (or -1) for ALL circles. All circles had the same parameter. Now, with latest release, it's not the same. Some circles have "Z Normal = 1" and other "Z Normal = -1". This causes in some software (for Example Bysoft from Bystronic, one of the most important sheetmetal laser producer) errors. I'm not an expert on AutoCAD and DXF/DWG file structure, but this propriety is visible in AutoCAD. Here the external circle haz Z normal -1 Here the internal circle has Z normal 1 Result on Bysoft, the shape isn't connected, seems Z-1 circles are mirrored Here the mirrored circles are visible, but sometime the risk is to produce part without some hole. Can you investigate with programmers? Thanks -
March 23, 2021 at 3:28 pm
ventura
SubscriberHere the files (you can try to generate the DXF from the STP)
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
March 24, 2021 at 6:36 am
subashni.satish
Forum ModeratorHello DrkAngl
Let me check with my team on this.
March 24, 2021 at 6:54 am
March 24, 2021 at 4:11 pm
ventura
SubscriberCustomer tried to set Autodesk RealDWG as export format but it not solved.
March 30, 2021 at 9:40 am
ventura
Subscriber Here the 2 different DXF file (one created with Ansys SpaceClaim 2021 and one with SpaceClaim 2020).
Can you ask to programmers?🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
April 6, 2021 at 2:02 pm
subashni.satish
I have reported a bug for this issue. Bug number 436851
April 30, 2021 at 10:05 am
ventura
SubscriberHello Subashni any news about it?
June 22, 2021 at 9:22 am
ventura
SubscriberSubashni Please can you inform when a fix is available?
June 22, 2021 at 11:52 am
subashni.satish
This bug is marked resolved for the upcoming version.
July 14, 2021 at 8:15 am
ventura
SubscriberSubashni customer want's to know if the fix is in Ansys 2021 R2 released after 9 September
June 22, 2021 at 11:57 am
ventura
Subscriberok thanks
July 16, 2021 at 8:46 am
July 16, 2021 at 9:55 am
subashni.satish
I have updated the development team that this issue is not resolved. I will keep you posted as I hear from them
September 28, 2021 at 10:10 am
ventura
SubscriberSubashni any news
September 28, 2021 at 11:02 am
ventura
SubscriberPlease can you change status "NOT ANSWERED" ? Thanks
December 3, 2021 at 3:34 pm
ventura
SubscriberThe problem is not solved.
- The topic ‘Z Normal in DXF-DWG Export’ is closed to new replies.
