May 6, 2021 at 12:15 pm
paul pladet
I am having trouble running Ansys spaceclaim on a computer. The server is running, the client pc can connect to the server with the Licensing Client Settings (although this takes a couple of seconds), but when starting SpaceClaim nothing happens. After a while i get the following error, see included image. We have tried to turn of the firwall and antivirus, but this still doesn't work.Â
Any ideas on what i can do to solve this issue?Â
May 7, 2021 at 3:45 am
Naresh Patre
Ansys EmployeeHello Matt Madore
Can you please assist with this license manager error?
May 7, 2021 at 11:20 am
ANSYS_MMadore
Forum ModeratorPaesc Could you please check if you have the environment variable ANSYSLI_ELASTIC specified on your machine? If so, make sure it is set to a value of 0.
- The topic ‘Connection timed out while reading data’ is closed to new replies.
5879
1306
