3D Design
3D Design
SHEET METAL BUG
    • Roberto
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      Hello I am attaching a video to indicate the error. I have projected an image but on the unfolded sheet metal it is not seen and if I save in dxf / dwg it does not export the lines. I have performed several tests and it is a BUG it is no longer possible to project the geometries on the unfolded sheets as they are not displayed, and if they are exported in dwg dxf they are not displayed. This BUG must be solved as soon as possible. I tested it with previous versions, the BUG is present from 2020R1 onwards   Best Regards
    • Naresh Patre
      Hello Roberto
      This bug looks similar to the one reported in below discussion
      BUG export dxf
    • Roberto
      Hello Naresh Patre
      is it fixed in the new version?
      Best Regards
    • Naresh Patre
      Hi Roberto
      It has been fixed in 2022 R1 (next year).
      • Roberto
        Naresh Patre Hello
        I update you that in the 2021R2 version the projection works almost completely.
        The thing that will need to be corrected is the exposure of the lines projected on the folds that still cannot export correctly.
        I attach video
        Best Regards
  • The topic ‘SHEET METAL BUG’ is closed to new replies.
