3D Design
3D Design
2D drawings in Viewer-only mode?
    • peter.kelly
      Hi
      I was interested to know whether an .scdoc file containing 3D geometry AND an associated 2D drawing would be able to be viewed when SpaceClaim opens in Viewer-only mode (cant test/deactivate my current license for some reason)?
      Thanks
      Peter
    • Naresh Patre
      Hello Peter
      I will check it and let you know.
    • Naresh Patre
      Hi Peter
      I just SpaceClaim in viewer-only (or reader) mode and I could view the 3D geometry as well as its associated 2D drawing.
    • peter.kelly
      Thanks Naresh
      Do you also know if there is also a way for a user to avoid the license pointer questions (a couple of cancel options need to be selected) before the software will open up in Viewer-only mode?
      The customer is interested in utilising Viewer-only mode for a non-designers who would permanently, have SC installed, but not have access to a license.
      Thanks
      Peter
    • Naresh Patre
      Hi Peter
      I don't think the pop-ups at the start could be avoided since the application always checks for license when it is luanched.
Viewing 4 reply threads
  • The topic ‘2D drawings in Viewer-only mode?’ is closed to new replies.
