August 30, 2021 at 10:18 am
ariel.kotulski
SubscriberHello, Working on the same model in Ansys Aim 2020 R2 error occurs: "Input string was not in a correct format".
What can be the reason?
BR,
August 30, 2021 at 11:09 am
Charudatta Bandgar
SubscriberHello Ariel Kotulski
I will need more information to understand the issue.
When are you getting this error? Do you get this while opening the model? Are you getting it for a specific file, or for all files? Is it occurring when you perform a certain action? Have you ever faced this issue before?
 Were you working on this model previously and it was not giving the error, or you have worked on this model in some other version of AIM?
Will it be possible for you to share the run files to me, I can look into it and see what could the issue be.
Regards.
August 30, 2021 at 11:32 am
ariel.kotulski
SubscriberHello, Sorry for lack of more informations. I'm doing analysis of snap fit from:Â 4) Insertion Force Prediction video. Problems occurs after start of the simulation, physics is solved in 26seconds, then it's aborted. Model was downloaded from Discovery forum, done according to the tutorial, the only difference is version of Aim. Tutorial was done on a version 2019 R2, I'm using 2020 R2 version. Â
- The topic ‘Ansys Discovery Aim 2020-R2’ is closed to new replies.
- FSAE CFD – Lesson 1 Preparation question (Using Discovery)
- Add-in Error Excel
- Missing SubDivWrapper.dll
3892
1414
1241
1118
1015
