September 23, 2021 at 12:40 pm
Roberto
SubscriberHello
Always in spaceclaim when you put an assembly on the table where inside you have imported geometries with errors, it often happens that the views / projections disappear from the drawing, or that saving the table in dxf / dwg from a saving error and not the saves or saves it by not exporting the geometries correctly.
Some time ago you told me that to solve the problem it was enough to repair the geometries with errors and in this way the problem is solved.
It takes a long time to fix the geometries sometimes.
Is it not possible to make sure that regardless of whether the geometry is damaged or not, the exports work and that there are no display errors in the drawing?Best Regards
September 24, 2021 at 5:42 am
Charudatta Bandgar
SubscriberHello Roberto
Let me look into this, I will get back to you.
Regards.
- The topic ‘Drawing format’ is closed to new replies.
5664
1890
1419
1304
