October 5, 2021 at 12:42 pm
sui sui
Subscriber? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsCannot be fully expanded -
October 5, 2021 at 12:53 pm
October 5, 2021 at 12:58 pm
sui sui
SubscriberThank you very much
October 6, 2021 at 5:07 am
Charudatta Bandgar
Subscriber尊敬的各位领导 sui sui 请看所附视频,我可以用测试.scdoc来做,但不能用设计2.scdoc,我还在试图了解原因是什么。 请遵循以下步骤。 1. 复制并粘贴金属板几何图形的外表面。 2.选择生成的表面并给出一个内部厚度。 3.选择新创建的几何体并将其转换为金属板。 4.选择面并点击展开工具。 监管。 _______________________________________________ English translation: Hello sui sui Please check the attached video, I was able to do with 測試.scdoc but not with 设计2.scdoc, I am still trying to understand what could the cause be. Steps to follow: 1. Copy and paste the outer surfaces of the sheet metal geometry.. 2. select the generated surface and give a inner thickness. 3. select the newly created geometry and convert it into sheet metal. 4. select the face and click the unfold tool. Regards.? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
October 7, 2021 at 2:43 am
sui sui
Subscriber非常感谢您的礼物,我期待着后续版本,我的愿望将实现,谢谢!
Viewing 4 reply threads
- The topic ‘Incomplete unfolding of sheet metal’ is closed to new replies.
1838
1387
1249
