November 22, 2021 at 2:27 pm
GUICAD
SubscriberHi,
The geometry is not correct for this part with step 203/204 and iges format.
it's ok with parasolid and step242.
i'll send you the part in separate email.
Thanks,
November 22, 2021 at 2:58 pm
Devendra Badgujar
Forum ModeratorHi GUICAD
I will look into this and get back to you.
November 23, 2021 at 3:13 pm
Devendra Badgujar
Generally Parasolid and STEP AP242 are recommended over STEP AP203 and IGES format.
Although I have filed a bug ( 554033 )for this issue and will let you if there is any update from the development team on this.
- The topic ‘import issue with step203/204 and iges’ is closed to new replies.
- Add-in Error Excel
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
1494
1386
1209
