December 22, 2021 at 3:02 pm
December 22, 2021 at 4:40 pmDevendra Badgujar Forum ModeratorHello David Rendall Does that happen with any file or with this specific file? Did you get the same error after importing other format files? Will it be possible for you to share these file, so that I can try them on my end.
December 22, 2021 at 5:07 pmrendall56 Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
 Hi Devendra, I tried several different .prt files created in NX, I have attached a couple of random part files here
December 23, 2021 at 6:09 amDevendra Badgujar Forum ModeratorHello David Rendall You are getting those messages due to the input NX file version not supported in SpaceClaim 2021 R2 version. Currently, SpaceClaim 2021 R2 supports NX1 through NX12 and UG v11 through 18, 1872, 1899, 1926. The next release of SpaceClaim (2022 R1) will support NX 1953. This version comes out in early 2022.
 (Note, I was able to open the .prt files created in NX you sent me in a SpaceClaim 2022 R1 build)Regards. -
December 23, 2021 at 9:42 amrendall56 SubscriberHello Devendra Badgujar If I postponed the trial until the latest build is available, would I be able to pick up the trial licence again? Do you have an estimate of which month 2022R1 will be available? Regards.
December 23, 2021 at 10:36 amDevendra Badgujar Forum ModeratorHello David Rendall Please contact your Sales Rep for Ansys to postpone the trial and pick it again. Also the new release 2022 R1 is estimated to be available early next year in the mid January. Regards. -
December 23, 2021 at 11:08 amrendall56 SubscriberDevendra Badgujar Is it best to un-install the version I have until the new version is available, or is easier to leave it in place? Regards.
December 23, 2021 at 11:25 amDevendra Badgujar Forum ModeratorDavid Rendall As you planning to postpone and pick it again after the new release, you can uninstall this version and install the new version when its available. Even if you leave it in place it won't be problem just you won't be able to use it as you will not have trial license available. But you will have to contact your Sales Rep regarding postponing the trial and pick it again.
December 23, 2021 at 11:33 amrendall56 SubscriberDevendra Badgujar Thanks Davendra, I have already been in touch with my Sales Rep, we agreed to talk again when the new version is up and running Regards.
- The topic ‘Licence Issue with Spaceclaim’ is closed to new replies.
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
                        4167
                        1487
                        1318
                        1171
 You are navigating away from the AIS Discovery experience
