3D Design
3D Design
    • Mirco Leurini
      Buon giorno,
      avremmo bisogno di capire come impostare il fattore K per lo sviluppo delle lamiere.
      Grazie mille
    • Devendra Badgujar
      Hi Mirco
      With a sheet metal design selected at the top level of the Structure tree, the K-Factor Type option displays in the Sheet Metal group of the Properties panel.
      By default, the K-factor type is set to Variable, but you can also set a constant K-factor. The Constant K-Factor type option allows you to enter a numerical value for the part. Using this option, you can map the design to other mainstream CAD functionality, or, adjust the design to a manufacturer's unique standards or tolerance levels to achieve various unfolding results.
      Please let me know if you need any further help on this.
      Regards
      • Roberto Granito
        Devendra Badgujar I solved, I called the customer
      • Devendra Badgujar
        Roberto Thank you!
  • The topic ‘Fattore K’ is closed to new replies.
