3D Design
3D Design
Failover feature ‘Discovery_level2’ is not available.. problems
    • EzgiYapici
      First of all, I looked for similar tickets on the forum. I opened a Discovery simulation license to my client. (floating) Installation and licensing seems fine. I checked. He can run SCDM. But when discovery opens, it only opens as read-only mode and gets the following error.
      "Failover feature 'Discovery-Level2' is not available.
      Request name disco_level2 does not exist in the licensing pool.
      No such feature exists.
      Feature : disco_level2
      License path: 1055@XXXX
      FlexNet Licensing error: -5.147"
      When I checked the license content, disco_level2 increment is located.
      I would be very grateful if you could help me solve the problem. I wish you good work.
      Ezgi Y.
    • subashni.satish
      Hello EzgiYapici
      Can you please confirm if this a Discovery Floating license?
      Can you also please share the client and server diagnostics?
      Please follow the steps at the below link to extract the same.
      Discovery Floating licensing: Gathering diagnostic information
    • EzgiYapici
      Hello  Subashni
      Thank you very much for your return.
      We were able to fix the problem by changing the Client settings.
      Thanks again for your help.
      Respects.
      Ezgi Y.
      • gioele.genazzi
        EzgiYapici Hi Ezgi,
        I also have the same problem. Can you please help me and tell me what did you do exactly fo fix this problem?
        Thank you very much in advance.
        Kind regards,
        Gioele
  • The topic ‘Failover feature ‘Discovery_level2’ is not available.. problems’ is closed to new replies.
