July 25, 2022 at 10:16 am
Ernesto Peters
SubscriberHello, how do we (company I work for) move the SpaceCLaim License server from my local pc to a network server as a service? We are getting erro in the lic.log saying "Invalid license key (inconsistent authentication code)
July 25, 2022 at 11:09 am
Devendra Badgujar
Forum ModeratorHello Ernesto Peters
Please go through this online help Documentation and see if that helps:
Ansys, Inc. Discovery Installation Guide
For floating license issues please gather diagnostics for review as mentioned in the below link:
Regards.
July 28, 2022 at 2:54 pm
Syed Saif Ali
SubscriberHello Devendra Badgujar ,
Can you please provide some specific solution to Ernesto Peters ?
His license is not getting excepted on the server side.
Do he need a new license file as he has changed server from local pc to network server?
Thanks,Ali
July 29, 2022 at 2:05 am
Devendra Badgujar
Forum ModeratorHello Ernesto Peters Syed Saif Ali
I will check with the team and get back to you.
Could you please share the diagnostics file as mentioned in the below link to ansys-discovery-support@ansys.com?
Regards.
July 29, 2022 at 7:17 am
Devendra Badgujar
It seems you probably changed something in the license file, that's the only way that error message occurs. You will need to process a license server change, using the Licensing Portal. Below is the link for Licensing Portal.
https://licensing.ansys.com/index.html
Ansys Licensing: Managing Activations - YouTube
Regards.
- The topic ‘Floating license server error’ is closed to new replies.
4708
1565
1386
1242
