using weak springs
    • Miguel Sanchez
      When using weak-springs (on or programme-controlled), after checking their reactions in results, how much these reactions should amount for in order to consider that they do not affect the rest of the results and the obtained solution is therefore valid? Is there any criterion to follow?
      Thanks.
    • Armin
      Hi Miguel.
      I believe it depends on the application but the general guideline is that the reaction forces of weak-springs should be close to zero as much as possible.
      Here is a link to a lesson that you may find helpful:
      Verifying and Validating the Model Setup - Lesson 1 - ANSYS Innovation Courses
      • Miguel Sanchez
        Thank you Armin. I´ll check it out.
  • The topic ‘using weak springs’ is closed to new replies.
