Error message while meshing: ‘mesh has uncovered edges’…?
    • Naresh
      Hi, I've been trying to save my ICEM mesh but when I try to, it says this:
      'Mesh has uncovered edges. Ansys fluent needs a complete boundary (lines in 2D) or it will give a variety of errors and not read in the mesh! If this was 2D hexa, perhaps your edges are not associated with perimeter curve'.
      what does this mean please?
    • Keyur Kanade
      You can check and fix blocking. Please use 'Check Bocks' under blocking.
      Please go through help manual for more details
      Keyur
      Fluids Engineering Courses | Ansys Innovation Courses
    • Naresh
      Hi, I tried the block checks, and it still shows the same error message when I try output the mesh?
      any other suggestions please?
    • Keyur Kanade
      You need to fix the blocking.
      Keyur
      • Majid Panahi
        Hello
        Dear Keyur
        I have the same problem, But when that selected the  above link, that no found in results
  • The topic ‘Error message while meshing: ‘mesh has uncovered edges’…?’ is closed to new replies.
