Couldn’t solve the solution. Static structural problem
    • Tin joksumnak
      Hello all, I am a student working on my project.
      I'm trying to do the ansys static analysis on my assembly and it's showing some errors. I have used the mesh with Method> Tetrahedrons>Patch independent Then i used the min size = 25mm for the both side of frame
      And the mesh statistics Nodes= 375725 and Elements = 219663 then I insert the load and supports like this
      aThen put some solution > Deformation and stress but it couldn't solve due to 2 warnings and 1 error "An unknown error occurred during solution.  Check the Solver Output on the Solution Information object for possible causes." then i checkout the solver output to find possible causes.but I don't understand it.
      Need some help
    • ErKo
      Hi
      See the error it says what you should try and modify an improve.
      All the best
      Erik
    • Rahul Kumbhar
      In Mechanical, at the top toolbar, there is Selection tab. use Mesh by ID option under selection tab and enter the element number in the error message. This will highlihgt the element. You can just remesh that body with better mesh.
      • Tin joksumnak
        I will try thank you.
        Thanks
    • Tin joksumnak
  • The topic ‘Couldn’t solve the solution. Static structural problem’ is closed to new replies.
