Explicit Dynamics using true stress or engineering stress?
    • Benjamin See
      I am currently doing a compression and impact simulation test on a lattice structure. I inserted a von mises stress probe on the entire structure to measure the stress.
      However, I am unsure if ANSYS calculates the true stress or the engineering stress in this case.
      Does anyone have any knowledge regarding this?
      Ansys results are True Stress
      • Benjamin See
        Thank you for the reply!
      • Benjamin See
        May I ask if it is possible to convert engineering stress to true stress in the same way as you convert engineering strain to true strain? With the formula of ln ( 1 + _ ).
      No, that is not correct. Please review the courses below.
      Here is one course on Metal Plasticity
      Here is another course on Plasticity
  • The topic ‘Explicit Dynamics using true stress or engineering stress?’ is closed to new replies.
