Photonics
Photonics
How to introduce an interfacial thermal resistance between two materials.
    • Souani.Safer
      I am modelling heating effect on illuminated metallic nanotip (coupling DGTD+HEAT), the model works well, the only problem that I have is how to introduce the interfacial thermal resistance between a metal and a dielectric in the model.
      Do I have to add a thermal resistive layer of 0.5 nm or 1 nm with a low thermal conductivity or another way but I do not see any possibility of adding an interfacial thermal resistance.
      Do you have any idea for solving this issue?
      Thanks in advance for your time and help.
      Best regards,
    • Guilin Sun
      The solver automatically counts the thermal resistance at the material interface, since their heating property is not the same. Please refer the solver physics  https://optics.ansys.com/hc/en-us/articles/360034917713-HEAT
      • Souani.Safer
        Thanks a lot for your reply and help.
        Best regards.
  • The topic ‘How to introduce an interfacial thermal resistance between two materials.’ is closed to new replies.
