Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › TARGE170 and arc line segments › Reply To: TARGE170 and arc line segments
February 22, 2023 at 5:50 pm
Hi Ethan,
Can you give more clarification or APDL commands which you used? Why do you need TARGET170 element on the line? is it in contact with other 1d elements? Normally first you should generate mesh on line (probably beams?) and then define contacts.
