Ansys Learning Forum Forums Discuss Simulation Photonics Y axis unit for Lumerical MODE varFDTD output (E, T & etc) Reply To: Y axis unit for Lumerical MODE varFDTD output (E, T & etc)
Amrita Pati
Typically, this happens when the fields in the simulations haven't decayed sufficiently. I would suggest you to increase the simulation time and rerun the simulation to see if the problem still persists.
Thank you.
