Ansys Learning Forum Forums Discuss Simulation Fluids Using Parallel capabilities within fluent 22.1 Reply To: Using Parallel capabilities within fluent 22.1
Atul Singh
It took you 6 days, to answer with "read through the manual"????????????????
I specifically quote that in the manual those things are not given properly. (see p4006 is written in the brackets), which should tell you , that I already have. !!
