TAGGED: element-distortion, fsi, highly-distorted, mechanical, transient
February 21, 2023 at 10:22 pm
dxc200018
SubscriberÂ
I have a distorted element error in my model.
My model is of a breast pump. The breast tissue is a hyperelastic tissue and the connection between the funnel and breast is frictionless.
The mesh is just created with the "automatic method" setting for both the funnel and the breast. I apply pressure on the breast tissue with a sinsoidal pressure profile. (I created the profile in excel and imported it).
I'm not sure how to resolve this error. I tried shrinking the mesh and changing the contact settings but the error persists.
Element 805353 (type = 1, SOLID187) (and maybe other elements) has
become highly distorted. Excessive distortion of elements is usually
a symptom indicating the need for corrective action elsewhere. Try
ramping the load up instead of step applying the load (KBC,1). You
may need to improve your mesh to obtain elements with better aspect
ratios. Also consider the behavior of materials, contact pairs,
and/or constraint equations. Please rule out other root causes of
this failure before attempting rezoning or nonlinear adaptive
solutions. If this message appears in the first iteration of first
substep, be sure to run shape checking of elements. -
February 22, 2023 at 12:58 am
Ankush Choudhary
Ansys Employee -
February 22, 2023 at 12:26 pm
peteroznewman
SubscriberI suggest you change the frictionless contact to frictional and type in a friction coefficient of 0.1 or higher. Friction can help stabilize a transient analysis.
February 22, 2023 at 5:40 pm
Akshay Maniyar
Ansys EmployeeHi dxc200018,
Try Peter's advice and watch the video Ankush recommended; both will be very helpful to you. Moreover, you might want to try using Ansys recent releases because the solver gets better with each new version, which will help you avoid distortion problems.
Thank you,
Akshay Maniyar
- The topic ‘Element distortion error in my Ansys Structural model’ is closed to new replies.
