Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Density of fluid affects the results and it makes the result wrong. › Reply To: Density of fluid affects the results and it makes the result wrong.
February 21, 2023 at 9:55 am
Sounds sensible. I suspect it's a solver where the flow jet entrains too much material from one of the two outlets and then pushes it all out of the other. What are you expecting to see?
