February 20, 2023 at 5:13 pmVanelle NoumbiapSubscriber
I simulate the condensation of r134 vapor into r134 liquid. I create the mass transfer in the vof model.R134 vapor inters at a temperature of 320 K and the saturation temperature is 308 K. After calculations, there is a temperature exchange but the transfer of mass r134 vapor to r134 liquid has not taken place. I've bien working on this project for weeks and i dont know why it doesnt work. However, i managed to model the evaporation of liquid r134 into vapor r134. I set the standard enthalpy of r134 liquid to zero and that of vapor r134 to 1.7e+07 but i have an error because ansys tells me that the latent heat must not be negative. Can you help me please ?
February 22, 2023 at 1:42 pmPrashanthAnsys Employee
HiÂ
Can you attach some screen grabs of the domain? Is the condensation expected over a wall?
- The topic ‘Condensation r134 vapor Vof model’ is closed to new replies.
- Non-Intersected faces found for matching interface periodic-walls
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Fluent fails with Intel MPI protocol on 2 nodes
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Cyclone (Stairmand) simulation using RSM
- error udf
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- Facing trouble regarding setting up boundary conditions for SOEC Modeling
- UDF, Fluent: Access count of iterations for “Steady Statistics”
1411
599
591
555
366
