TAGGED: apdl, mechanical, moment, node, result-postprocessing
January 29, 2023 at 8:41 am
str35
SubscriberI'm trying to extract nodal forces and nodal moments using post-processing command.
I tried PRESOL command like below:
/POST1! Start the post-processing processPRESOL,S,! End the post-processing process/POST26But i got a warning message: "The geometry is not available. The PRESOL command is ignored."How can i extract nodal forces/moments node by node ?Thank you. -
January 30, 2023 at 5:56 am
Ashish Khemka
Forum ModeratorHi,
Can you issue the SET command to select a relevant result and also issue ALLSEL, ALL to select everything?
Ashish Khemka
- The topic ‘Extract Nodal Forces and Nodal Moments’ is closed to new replies.
1305
