Are CFL-Number, Courant-Number and Flow-Courant-Number the same thing?
    • oll5hbdfk
      Hello everyone,
      the title is the question.
      Depending on what I choose in fluent under Setup-General and Solution-Methods, fluent may ask for a Courant-Number or a Flow-Courant-Number. Additionally in the documentation I find the term CFL-Number (e.g. Fluent 2021R1 Theory Guide 28.4.4.2 Under-Relaxation of Equations). Do these terms mean the same thing? I know that they are closely related, but are there small but decisive differences or do they mean exactly the same?
    • SRP
      CFL-Number, Courant Number, and Flow-Courant-Number are all interchangeable words.
      Thank you
    • DrAmine
      Yes.
    • DrAmine
      The CFL number used for the Coupled Solver is however something totally different: you should rather interpret it as a sort of under-relaxation has nothing to do with temporal evolution or discreization rather to make matrix more diagonally dominated.
      • oll5hbdfk
        OK, so the CFL number when using coupled means something different than the CFL number when using a segregated solver. But "coupled CFL" and "coupled Courant number" is the same. Do I get this right?
    • DrAmine
      The CFL number used as Numerical Method Input has nothing to do with real temporal discretization and time evolution of the solution.
Viewing 4 reply threads
  • The topic ‘Are CFL-Number, Courant-Number and Flow-Courant-Number the same thing?’ is closed to new replies.
