mismatched force values from Fluent force report and shear stress integral
    • Edmond Lam
      Hi all, I am simulating a laminar multiphase flow in Fluent using the VOF model. However, when I am trying to extract forces acting on a no-slip wall parallel to the xz plane, the value from Fluent force report using the direction vector (1,0,0) is different from the one reported by a surface integral of X-wall shear stress on the same surface. In fact, in the Fluent force report, the viscous force component along the direction vector (0,1,0) is non-zero, which does not make sense for a wall parallel to the xz plane. In comparison, the surface integral of Y-wall shear stress on the same surface results in a value almost equal to zero (E-27). Are there any ideas? Thanks.
    • SRP
      Will you kindly send a screenshot of the geometry, force report results, and surface integral of the shear stress in the relevant direction?
      Thank you
      Saurabh
    • Edmond Lam
      Hi Saurabh,
      Thank you for your reply.
      The geometry is very simple, only a box. The surface I am interested in is the bottom surface, which is parallel to the xz plane.
      Here are the results from the force reports and surface integrals:
      As you can see, the forces are very different.
      This mismatch seems to occur when on this surface there are 2 phases.
    • Amine Ben Hadj Ali
      Can you please include the report of the force vector and not the dot product of the force vector with the direction.
    • Edmond Lam
      Here it is, thanks:
      As mentioned, this mismatch seems to occur only when there are 2 phases in contact with the wall. (I have 2 phases in total for the case.)
      I have wall adhesion turned on for the wall and a specfied contact angle. The surface tension is modelled using CSF. I am wondering if using these models adds additional terms to the force calculation on the wall in Fluent.
      Thank you very much.
      Surface tension force should is not part of the force report.
      For a VOF case with two phases I am not able to reproduce your issue. Is your problem reproducable on a simple dummy case?
    • Edmond Lam
      I ran two simple dummy cases for 10 time steps after patching a liquid droplet with a velocity in -x.
      The boundary conditions for the 2 cases are exactly the same.
      There is no gravity, and the wall that I am measuring forces is at the bottom with wall adhesion enabled, surface tension modelled with CSF.
      1) a liquid droplet moving in the -x direction in its vapour:
      Here, with only one phase (vapour) in contact with the bottom wall, integral of x-wall shear stress is exactly the same as the force report in (1 0 0). The integral of static pressure is also exactly the same as the pressure component in force report in (0 1 0). However, although the integral of y-wall shear stress is almost zero, the viscous component in force report in (0 1 0) is non-zero, or at least much larger.
      2) a liquid droplet moving in the -x direction in its vapour, but also touching the bottom wall:
      Here, with both phases in contact with the bottom wall, the integral of x-wall shear stress no longer matches the force report in (1 0 0). The integral of static pressure also no longer matches the pressure component in force report in (0 1 0). And similarly, although the integral of y-wall shear stress is still almost zero, the viscous component in force report in (0 1 0) is still much larger.
      Can you check if there is a mismatch if you disable the surface tension force?
    • Edmond Lam
      The mismatch is gone when wall adhesion or surface tension modelling is disabled. But the integral of y-wall shear stress (E-27, almost zero) is still different from the viscous component of the force report in the (0 1 0) direction (non-zero).
Viewing 8 reply threads
  • The topic ‘mismatched force values from Fluent force report and shear stress integral’ is closed to new replies.
