January 17, 2023 at 11:52 pm
dxc200018
SubscriberHi, I run Ansys on a Linux cluster to do FSi simulations. I used to use Ansys 19.2 , but I'm switching to 2022 R2.
I used to have a batch file that would initialise like this
"# starting setting up system coupling ###############################################################/opt/ohpc/pub/site-licensed/ansys/19.2/v192/aisol/.workbench -cmd ansys.services.systemcoupling.exe -inputFile System_Coupling.sci &sleep 30# Run Fluent ########################################################################################cd FluidFlow_CmdLine/opt/ohpc/pub/site-licensed/ansys/19.2/v192/fluent/bin/fluent 3ddp -g -cnf=../HOSTS_Fluent.txt -t$np_f -scport=$PORTN -schost=$HOSTN -scname="$LINE5" -i ./FFF.jou > ./FLUENT.out &sleep 3cd ..# Run Mechanical ####################################################################################cd Structural_CmdLine/opt/ohpc/pub/site-licensed/ansys/19.2/v192/ansys/bin/ansys192 -b nolist -scport $PORTN -schost $HOSTN -scname "$LINE3" -i ./structural.dat -o ANSYS.out -np $np_m -dis -machines $HOSTS"ÂI'm reading the documentation to try to update my workflow but I'm still confused.ÂThe manual for 2022 R2 doesn't seem to specify an input file in their section on scriptingIs there a need to specify an input file when running coupling in 2022 R2?If I still need an input file, is there still a way to export a ".sci" file from system coupling in Ansys 2022 R2 or is there a different input file?ÂThanks to anyone who can help me. -
January 19, 2023 at 9:13 am
Rahul
Ansys EmployeeHi,
Please refer Exporting a System Coupling Setup (ansys.com) from system coupling manual to export input file required for system coupling.ÂHope this helps you.!
- The topic ‘Updating my FSI workflow batch script from Ansys 19.2 to Ansys 2022 R2’ is closed to new replies.
1311
